Monroe air shocks
9 reading
426K views 1.2K replies 138 participants last post by  dmdsr
#1 ·
Has anyone done the DIY air ride system with the corvette shocks. I am seeing a lot of other forums talking about this and getting it done for around $250. Any input from anyone.
#975 ·
I mounted it directly to the frame that the radio rides in. I Had my 93C in the same spot mounted vertically but the 98C I put in horizontally. The 98C actually took up less space and was easier to mount. I also added a relay to send power to the new compressor instead of running it all through the switch. I like it a lot more now.
#977 ·
It's the exact same thing as the DIY set up with energy suspension bushing......you can piece it together cheaper (which I'm sure everyone is going to tell you) but fuck it there is something to be said about convenience and just opening a box with all the right shit in it
There's a lot of places selling these kits now, hell one of "the big guys" is selling the same damn kit for $900
Sent from Motorcycle.com App
#983 ·
Well for 2 weeks I've been thinking about doing this mod, I've read this ENTIRE thread 4 times, every post....I just placed my order for all the parts. I changed a few part numbers saving a few bucks here and there. I called and scoured the internet and no one had gabriels. O'Reillys had Monroe in stock and was right around the corner from my house so if I had a warranty issue I could go right back. Picked the shocks up today and hopefully everything will be delivered by the end of the week. Thank you to everyone who has provided information regarding their order list and part numbers. I water tested shocks all day and they are currently holding at 110psi. I'll check them tomorrow. I also plan to weld the eyelids over the crappy spot weld on the shocks. Thanks again.
#986 ·
I pulled my set up off my bike and will be selling it. I had one shock that blew, on a trip (I think it was suspect when new). I've got a new set of Monroes, but will include the remaining good shock as well. Pictures and ad in classifieds, soon.
#996 ·
Thanks guys, the 98c is still a mystery. Viair site doesnt even list a filter for the 97/98series. i took front cover off, just crank case, no filter there. it does look like ther is an inlet valve on the bottom of the piston so it must pull intake air from this area. I have no idea how this works but many are using this compressor with good luck, so i'll leave well enough alone.
#1,000 ·
Does anybody who uses the monroes use a lowering block as well? I'm curious if the tire rubs when there's no air in the system. I had a set of 1" blocks on before I did the monroes so I already have a set to use but I'm concerned about rubbing in case there's a failure while riding.
#1,002 ·
How much clearance do you have or think you may have with that fender? Is it ridable if there's no air? Like I said I'm worried about a possible failure on the road. I want to be able to at least ride it out of harms way sorta speak and not damage the fender or tire
