621 - 640 of 1,151 Posts
What purpose is the straps? I'm not running any
mike
2011 FLTRU
Southaven Ms
I was going to make a set of these, but decided against it. Anyway, I checked with my local Ace Hardware, they have the cable and the clamps and said they'd have no problem making up whatever length I wanted.
Out of curiosity, why did you decide against the cable? Is there a better method or just decided no limiter?
mike
2011 FLTRU
Southaven Ms
The straps are not needed. Me being 5'6". I want to limit travel to 12" plus it will allow me to firm up my ride depending on weight needs (1up, 2up, fully loaded) without going over 12" shock length.
I know there was a write-up or photos on how to get those limiter straps. Anyone know where that's at? or even what page on this thread it's on?
Can't remember how far back it was but it's pretty straight forward get some 1/8" plastic coated cable at hardware store with 4 swedging eyelet kits and borrow or buy cable crimps.
Air the bike up to a level your comfortable with while in the saddle and measure the distance between shock bolts center to center. That's the length you want your cables. Strip back the plastic coating on the end of the cable enough to complete the eyelet and crimp wedge this is important because you get max strength out of the eye.
Once first eye is complete then measure and mark you center to center and cut plus 4" again strip casing from cable assemble the eye and double check measurement adjust and crimp
Buy 4 1/2 flat washers and 4 bolts 1/4 inch longer than the ones you have now and assemble with washer on both sides of the cable and tighten
I think that's it
I think that's it
You the man lundboy. I knew I saw it before but didn't know where. Now I know where it's at so I can do the mod. :)
Thanks for the details on how to make and then thanks for the link posted above. I did an ebay search and found some 12" limiting straps.
Ok quick question. Why do you have to have the electric dump valve after the speed valve. Can you just plug the third line coming out of the speed valve and dump the air that way.
