Hey GunMetal I was looking to do the same thing this weekend but was just thinking of tapping into the wiring inside the fairing before the connectors. Do you remember what color the wires are? Also did you run a relay for your compressor?
Thanks Mark
Hi , you can't tap inside the fairing, if you do that you will loose volume control from the handlebars.
Mine is a 2006 and I don't know if the wire colors will be the same on yours, if you can get a hold of the wire diagrams from yours will be better.
The connector on the left side controls on mine have 12 wires, the 3 wires I used are on the same side of 6, the colors are grey/green, brown/black and purple/black.
The Pl/Bl needs to be disconnected from the connector and will be the power wire coming from your relay and or fuse.
Now you have to pull all the wires out of the black plastic cover, the Gy/Gr is split inside, one goes to the radio control switch, cut the part that goes to the CB control and add a length or wire enough to go to the fairing, do the same with the Br/Bk.
I use the Gy/Gr as the up and the Br/Bk as the down.
Yes I have a relay from before when I was using the CVO trunk switch.
If you need more information send me a PM, I will give you my ph nbr
