901 - 920 of 1,151 Posts
Went out for a 200 mile ride today to visit a friend. He has the Gabriel hijackers 49307 on his glide, he just pumps them up a little and no bottoming out. I pushed down on his back and felt stiff, I pushed on my rear shocks with 60 psi bottomed out. I am going to take them off and replace them with the Gabriel hijackers. He has done 6 other set up for other guys no problem. I might have gotten some bad shocks. Just my luck. Need to get these on by Thursday, River run is here, Or will just install stock ones till when I get back.
This is where I installed my pump.
If you read back a lil you see that most are running well over 60psi. I dont have a gauge but if im aired down and need to ride ill air back up to the max then adjust down to find my comfort zone. I dont bottom out but do find the monroes are slightly stiffer than stock when i ride solo.
I'm 180 and run about 80-85 when riding solo. I do find it rough but no harder than the stock FLTRX shocks it came with....so having the ability to raise and lower was pretty much the only plus for me. I will say though that riding two up and gear loaded does yield a softer ride than stock shocks, not a huge difference but just enough to notice.
BTW - 2up I ride at about 110-120 psi depends on load.
Paul, sense you are always good at this - link me the How to video/Pic thread,... I'm lazy today (again).:D. Oh, please sir.
I can't do mine
weightd the options
I favor a high lean over ground clearance
feel like the dumb kid in school, but can't put it on the bike since I have a lanky frame to throw around corners
science end of it is good, voltage manipulation and appreciated execution, always received
a bummer, cause nothing say cool bike like dropping that sh*t..
still a fan.. great thread
I can't do mine
weightd the options
You know while riding you can air up so you get the lean right? Fully aired up the monoroes are 14"
I can't do mine
weightd the options
Nice thing about having this is that you can drop it for the cool times & raise it when needed & the difference in the low & high is great. Some times you come across a steep exit coming out of a gas station, house, bar, ect ect. You normally would drag your pipes & you cringe, well you can raise it up & they won't hit. Mine are Rhinehart copy cats & they are long (about 3-4 " longer) I kept bottoming out on my pipes until I did this mod. Now, even with 2 up & my wife & I are not on the small side. Around 500# between the both of us. Plus I can lower it down to make it easier for my wife to get on.
Toby
great idea
but now it's even more - stock momentary switch is the
what you had just posted is kinda what I was thinking, assuming a $140 would cost me a couple grand total with all tolls - deep bag kit + - nice or why bother
great idea - I think I'll really check someone elses out first - haven't got a case of the 'got-to's' yet still at 'that's cool'
Ups just stopped by again.lol. Ridepro solenoid block with everything you need. 2 supply ports coming in, 2 feeds going out, 2 exhaust ports, & 2 ports for gauges. Bought it from Summit Racing $250 shipped. Super nice setup.
