Dear dr. Ruth, before I go and waste a lot of money at the local MOCO I need some pointers to locate the problem.
My bike is a '01 FLTRSEI2 with 28k on the odo. It was imported from FL (probably had its share of sun and warmth)with no previous service record with it.
The engine is stock and last year it got an overhaul (pulled the 203-cams and replaced them with new ones also replaced one lifter). I was, to say the least, a little surprised with all the problems found...makes me wonder if my bike was a star at some HOGMANIA!
I hade the bike tested in a Dyno recently. The local MOCO had me sign a waiver on any warranty regarding the engine (I'm kind of regretting that, as this migh be the core of my recent problem).
My bike has, of course, the dreaded M&M EFI which in itself makes a lot of problems when starting cold (it sometimes stops after a sudden drop in RPMs).
So, to my latest chagrin - I now have more vibrations in the engine than before the Dyno-run. It's clearly noticeable in the floorboards to the extent that my feet starts to "sleep"! I even have more oil-slobbering so this makes me wonder if I'm having a serious problem with the engine or if it's just "normal" wear & tear (as often said at MOCO!)
Yours sincerely
Yours sincerely
