After the negative posts on the SE Pro Stage III kit I visited with my buddies at Strokers USA and got some new suggestions. They recommend a S&S 106 Hot Setup kit with 585 cams. It's about $400 more than the SE kit because the tuner doesn't come with it. Any thoughts out there on this kit?
Thanks for the help I appreciate the help
RR
We have been boring those cylinders to 107" here since 2007,(and boring H-D cylinders for almost 30 years) with final hone with a 400 grit stone, then plateau honed, with both cylinder base and head gasket surface's prepped.
Complete with all the Cometic gaskets needed, ring end gaps set, rings installed on the pistons.............only $600.00
88-98" same/same.
On a side note we have these on 4 continents..........:)
Scott
