1 - 12 of 12 Posts
Has anyone heard anything good or bad about the Screamin Eagle Pro Stage III kit,want some more poop for my 2011. The # look pretty good on paper?
forged aluminum 10.5:1 pistons,SE259E cams, high performance valve springs and perfect fit push rods, EFI Super tuner, and 103 cylinders: they're claiming almost 110 TQ and a little over 95 HP
Banned
that's rated in crank HP/tq,not rear wheel.im not sure what it costs,(I don't use SE stuff in our builds) but im sure you can get a lot more bang for your bucks going aftermarket.ide look into a 107" kit,S&S .585 cams with 1.900/1.630 headwork,115/120+ with even mild headwork
Many combinations available for power over/above from what that Squealin' Seagull kit(s) offer.
Torque is paramount in a touring combination, and then the ability to have that curve carry into the later rpm band really pulls it all togather.
Bob Wood, Crane, Andrews, the new S&S cams will all do it, set up correctly, as our many decades of 6-7 day work-weeks have taught us.
NO magic cams out there.:)
Scott
Before ya buy that screaming eagle 3 kit take a long look at the drago stage 2.5 kit. That's the one I'm holding out for till my bike is payed off.
A good low end/mid range cam will give you more then enough git up and go. Cams such as the Woods 222 or T-man 555 will give you around 107 to 110 ft lbs of torque. Torque is way more important then HP IMO.
With one of the quality shops on this forum your going to get a pair of cylinders that are specifically bored and honed to exacting dimensions of the pistons that goes with them. Do yourself a favor and go this route, even if it costs you a little more.
My 103 with cam only (TW-222) made 115 TQ and 95 HP. You might talk to our Dragos, Hillside, Fuelmoto, VeeTwin about cams and/or a big bore kit. You'll get more bang for your buck from those guys.
Good luck.
Scott
I think Scott sums it up perfectly...
1 - 12 of 12 Posts
