http://youtu.be/nnRT0Z4LS30
2007 road glide with stage 3 kit and got noise from front cylinder noise is worse when driving. Changed out my exhaust gaskets and still making the noise. Maybe head gasket?? not sure any help would be great
Kevin
Can't tell what exhaust you have but are there any 02 Sensors bungs in the front pipe?If so check for tightness of the bung plug.
its a bub 2to1 and there are sensors in there and they are tight.
Found the problem the compression release came loose out of the head and caused a very bad leak.
