1 - 3 of 3 Posts
Your PC shop should answer that because you won't want to leave them off with them if the answer is no. High Temp Ceramic PC should hold if the prep, application and remainder of work is done properly.
I got some rust on mine after running thru some salt water. I had them ceramic coated. They first sand blast part to remove original surface then ceramic coat. All Rush pipes are ceramic coated. Also, I believe Drago's are ceramic coated. :D
1 - 3 of 3 Posts
