For starters, I pay for my own stuff, I'm not an employee of a shock company, nor am I sponsored by anyone,
I've run Progressive, Ricor, JRI, Ohlins, and now Pro Action shocks on my Harleys. I've tried Progressive Monotubes, Ricor Intiminators, and Ricors with Racetech springs in my forks. My Roadie's front end has needed help for a while, and I've researched the hell out of my options. While I'm sure that the 30mm Ohlins kit that Howard sells are amazing, they're just not in the budget. I was set to do the Ricor/Racetech setup again when I stumbled across Pro Action's kit. Spent about 40 minutes on the phone with George there, and got the lowdown on what they do. I won't go into detail, but basically it's new damper rods, custom-wound springs, and heavier oil. I was intrigued. So I made an appointment and rode up last Monday. The PA Turnpike is a rough road, so I got to feel the full effect of how lousy the stock front end is. I also noticed the back of the bike kicking me (I'm running Ohlins 2-1/2). I got there, they asked my weight, how often I rode 2-up, how often I had the Tour Pak on, and how aggressively I rode. Then they asked if I wanted to try the rear shocks. They offer a 30 day "test ride", so I said sure.
George's team rebuilt my forks and swapped the shocks out in a few hours. It's like getting a suit custom tailored. They sent me out on a test ride to see what I thought, and damn....Their $300 front fork solution is amazing. It's much stiffer than stock - which is fine - but the amazing thing is that you're not crashing through 2" of fork travel every time you touch the front brake. It's "sports car firm". The compliance is there, but all the pitch forwards and backwards is gone. Grab a handful of brake and the bike stays relatively level. Pounce on the throttle, and you're not staring at the sky. The front end is far and away better than anything I've had before. And for $300 it's a damn bargain.
The shocks though are what you feel, as they're what's holding the bulk of the bike's weight. I've got 450 miles on them, and I've got them dialed in perfectly. Today I threw everything the s*itty roads around here could offer. Farm roads, gravel, frost heaves, 2" bridge joints. The Pro Action shocks are really, really good. Once I had them dialed in, they ate up everything I could throw at them. After a 200 mile day, I got home, ran a 15-mile loop by my house that's a shock-punisher, whipped the jack out, and put the Ohlins back on. Then I did it again. Same bike, same rider, same day, just 10 minutes later. The Ohlins, between the extra 5/8" stroke and what is clearly better damping are the better shock on lousy roads.
Now this is not taking anything away from the Pro Action shocks. They're really, really good. Far better than the JRIs or the Ricors. And if I lived farther south with better roads they'd be great. And I'm going to call them tomorrow to see if they have any tuning advice. But frankly I know what I know, and they're set as good as they're going to get.
So I unhesitatingly recommend Pro Action. The staff is wonderful, and at $300 the front end kit is a bargain. Their shocks are better than most, and for many people they'll be better than fine. For the s*it roads I ride on, they just can't keep up with the Ohlins.
