1 - 4 of 4 Posts
I have my inner fairing off and ready to go to the painter this weekend and I need to make the holes for the speakers that are facing the Forks. I think I remember a install tread but the search option is not working with my phone.
What size hole saw for 6 1/2 speakers?
How do you locate where the hole will go? Measurements or wing it?
What is the max mounting depth?
Should I go with a PBR300x2 with 2 speakers per channel or PBR300x4? Speakers are a older set of Focal 165 with a rating of 60watts rms and 120 peak @ 4 ohms
Thanks Jim
I personally like the PBR 300x2 better, and I have both amps. If you send me a PM with your e-mail I can send you more info on the install. If you have the speakers you are going to use they are the best template.
1 - 4 of 4 Posts
