1 - 11 of 11 Posts
my alpine ktp445u that i installed 08/12 has kicked the bucket, could using 2 & 4 ohm speakers caused any damage? what a good amp to replace it with? im thinking rockford pbr300x4.
2021 RG special in Snake Venom
Cerwin Vega B4. I have the B2 and it has some serious power for being so small
Yes using 2 and 4 ohm speakers together could have caused damage depending on how they were wired and the specs of the amp.
PBR 300x4 is 4 ohm only.
Arc Moto 600.4 and Cerwin vega B4 are 2ohm stable.
If you don't know about wiring audio up, let someone that does do it. Between blown speakers and amps, it can go south in a hurry!
Good luck.
I'd stay away from anything made by Rockford, I see to many people selling them after they have been RMA'd twice.
I've been running the ktp445u for 2 years now no issues, I have it running 2 JL 6.6's and 2 JL 1" tweeters.
For my rear I'm running a JL 400/4 Bridged to to JL 8.8's
I'm not a expert but I would run either 2ohm or 4ohm speakers off 1 amp, I wouldn't mix and match on the same amp.
J&M ROKKER amps are very dependable, will put out alot of power, will work with 2 or 4 ohm speakers, and carry a lifetime warranty to the original purchaser ,,,,,(((see J&M ROKKER Series Components for Harley Baggers ,,,,,,,
I have the j&m rokker amp with a set of their 71/4 speakers upfront and a set of hertz deci 6x9 in my saddle bags ( hertz speakers @ 4ohm and j&m @ 2ohm)... I can cruise the highway at 85 with a half helmet, ear plugs in and the volume not at full volume and hear everything crystal clear. I'm using the AV Aquatics head unit... Just my opinion from actual use...
· Another ICON
Look into the arc moto600.4. Awesome amp and will fit inside the fairing.
I've heard some really good things about this amp, and the fact it will fit in the fairing has me considering it seriously.
1 - 11 of 11 Posts
