1 - 9 of 9 Posts
Just installed my hertz with the ARC adapter rings. Fairing wont go back on. No matter which way I position the rings. The stick out too far.
What adapter rings do I need to make the Hertz HCX 165s fit inside the fairings?
I just went through this with the ARC adapters and Polk speakers... Rotate the speaker adapters so they move the speakers in towards the gauges... It will give you an extra 1/4" and it's just enough to get the fairing back on.... Hard to explain but there are 3 holes for the mount to attach to the fairing but you can rotate it... and it will move the orientation of the speakers....
thank, I just turned them inward using the top, bottom, and inner most screw hole. Fairing now goes on. It is still slightly touching but I can get it all the way in place.
Well I still had issues after turning them the right way. Fairing would not sit flush all the way down. After further inspection, I found that the fairing was sitting on the top edge of the ARC adapter rings. Dremel grinder quickly won the battle.
Anyone else had this issue?
I just had this issue with the Hertz HCX 165's as well. I couldn't get the ARC adapters to work and instead of struggling I just bought the Hawg Wired adapters. They fit without cutting and they are half as tall as the ARC adapters. No problems with the speakers hitting the fairing anymore.
i didn't use the arc but had some issues initially with the hawg wired. i learned that whatever rings you use these speakers are a tight fit. what worked for me was to loosen the inner fairing bolts just a little so they are snug but not loose. i then fitted the fairing up and flexed things around so the fairing fit. next removed outer fairing and retorqued inner fairing 4 bolts. after that i was able to fit the outer fairing. it is a tight fit and you need to be very familiar with how the inner and outer fairing mate together, paying special attention to the fin tabs.
good luck, i know the arc rings work, as do the hawgwired. just take your time and it will eventually make sense. it is tight, no getting around it.
How many Amps did you install.... Even after my bench grinder won my battle with 2 amps and the HID lights my fairing is tight...... I dread having to take it off again...... LOL...
I only did one amp
1 - 9 of 9 Posts
