1 - 2 of 2 Posts
ok..If I replace my stock HK head unit with a new Sony head unit I want, I have a question. The stock HK unit is 2 ohm and the Sony unit is 4 ohm..right now I have a PBR 300x 2 powering a pair of J&M Rokkers. Will the swap out work just like stock since it is 4ohm.. Will I be able to use this head unit without swapping out for new amps and 4 ohm speakers
You can swap the head unit with no issues. Since you are using the amp you will not be using the amp section of the head unit. Doesn't matter at all what ohm the head unit is putting out whether it is the old HD unit or the new Sony unit. Quit using the line inputs of the amp and use the RCA inputs.
1 - 2 of 2 Posts
