1500 Hundred Miles 2011 RGC103
Im going to assume its a bad brake switch like others have had. This is what I found for codes.
ECM
P0572 Brake Switch Low
P0031 02 Heater Low/Open - Not sure what this one means
TSM/TSSM/HFSM
b1122 Right Turn Output Fault
Speedometer
b1006 Accessory Line overvoltage - Not sure about this one either
Tachometer
ABS
C1094 Front Brake Switch always on
C1214 Rear Brake Switch always on
:mad::mad::mad::mad::mad::mad:
I may have a couple things going on, I do have a brake switch issue. the rubber boot was hanging up the front brake switch, Fixed that and now even if i wiggle the lever up and down the brake lights go on. The cruise still doesnt work. I think I may have screwed that one up while attempting to install the chrome switch caps. Im going to reset the codes today and see what happens.
May have a pinched wire on the right side.
The cruise won't work with brake trouble codes present or if the brake switch is sending a signal.
