1 - 4 of 4 Posts
Welcome to the board. Since you have an evo i have a question for you. What have you used to tighten the rear rocker box down with? Did you get the speciality tool or cut down an allen wrench?
What bike is it in? If it's rubber mounted, you can typically tug on the motor a little bit enough to squeeze your allen in there. It is handy to trim the allen down first, though. Check out Griots garage webpage. They have a handy little tool set with a bunch of different tips that has saved me in numerous tight spots on my Evo's and TC's!! It has a screw driver adaptor and a ratchet adaptor.
I don't remember the exact yr, this is a friends bike,but it is a 90's ultra classic. Cutting down an allen is what i planned on doing.
1 - 4 of 4 Posts
