1 - 20 of 23 Posts
So... Im buying an 2009 RG from a private party through the HD Dealer, and I'm trying to figure out if the Odometer has been swapped out, or whatever.
I bought a 2001 Springer from a Dealer years ago and learned that the speedo was swapped out and now the 40k I thought were on the bike are nothing but a guess at this point.
How can I verify?
The bike is 2 owner, 10100 miles, metal, and paint look great, the tire is worn on the back, front fine.
Vehicle history report returns fine..
Thoughts?
Wanna be Roadglider.. :)
It's a 2009. I would think the average rider would put that many miles on that bike. The likes of most of us, that would be a summer trip. Have them check compression and look to see if the front tire is OEM. That should tell you all you need to know.
Thanks for the reply..
For compression, what needs to be looked at?
As for the front tire if its NOT oem then what?
Thanks.. for walking it through..
David
Just have the dealer hook up his digital technician, and read out the mileage from the ECM.
The front tire won't really tell you anything because the tire could be changed at a HD dealer and the replacement tire is the same as a OEM tire.
If the odd o meter has been swapped out , the dealer should have verified the mileage on the old one prior to the order for the new one , and that mileage should have been entered on to the new unit .. That does not stop someone from disconnecting the old one either .. I know one person who does it on every bike ..
The ECM will be correct for the actual mileage and it should show that mileage when the odometer was changed with the replacement. I have a 2015 RGS and changed out my gauges from white face to black face and the ECM kept the correct mileage on the display.
OEM Front and rear tires, the Rear is at 3/32 and needs changed.
The ECM shows the miles on the bike. They check out for what the Odometer shows.
Swaping the speedo will not change the millage on the motor cycle since the ecm will send the millage to the speedometer that is the way I understand this maybe I'm wrong.
Envoyé de mon Nexus 5 en utilisant Tapatalk
What if anything else should I be considering?
Mileage checks out, no fault codes, bike looks good. How does it run, sound and ride? All checks out and it's what you want, have them put tires on it as part of your deal and buy it. I know guys that have bikes older than this one with less miles. I think it's criminal to have a bike and not ride it but to each his or her own. My 2 cents
The ECM does not send the mileage to the odometer. If you have 3200 miles on the ECM, and you change your odometer to one that has 1000 miles, the mileage on the odometer will start going up from 1000. But it won't "catch up". They will always be off from each other.
If you want the miles to match from the ECM, you have to order a NEW speedometer, and have the Harley FACTORY match it. The dealer can't do it, only the factory. That keeps dealers honest.
That's exactly what I figured. That's good you got the info and know its true. Sounds like a great bike. Good luck.
there's a lot of 'guesswork' with speedometers. the ecm does store mileage in it, but it does not send that mileage to the speedometer.
i just recently replaced the gauges on my wife's bike with a full set of cvo gauges. when i ordered them, i had to have a mileage number for them to 'reinstate' on the odometer. or i could have left it at zero. when the new gauge came in, it was set to the requested mileage, and had a sticker on the back of it that basically said it was a replacement speedo.
when doing the replacement, the odometer will lock to the ecm after 31 miles. so for the first 31 miles, the display is 'different'. it counts backwards, all the functions aren't available, etc. but after it locks, all is good.
now concerning locking. from what i understand, and have been told by others, is that if you try to swap a speedo after it has been locked, your display will read 'vin err' and not work properly. i didn't want any problems, so i elected to go with all new gauges instead of a used set. besides, from pcpain, the new set was not much more than folks were asking for a used set, and if i had to buy a new speedo, it would have bumped the cost higher than new.
of course, this is all concerning newer, (ish?) gauges. i'm sure if you go back far enough, this won't apply.
that was just general info, and my experience. i guess the big takeaway would be that if you were looking at a used bike, and had concerns that the mileage was incorrect due to speedo swap, then you could always pop the 2 screws out of the instrument cluster and look at the back of the speedo for a 'mileage reinstated' sticker......
Reactions: Elwha101
A date time stamp? On the rubber as a mfg date?
Yes, it will tell you what year and month it was made.
Edit: That is why when buying from Motorcycle Superstore you always need to check the dates of the tires manufacture date. It's always been rumored that they buy loads of tires where the tires are close to being out of the range that the dealerships or stocking shops get from the venders. It pays to check every time you order one of these good deals on tires.
Not true, it will have a date time stamp on it.
Just a manufactures date of when the tire was made. Who can say that the tire wasn't changed by the HD dealer and they got a 2 or 3 year old tire put on.
In most case people just don't check the dates on the tires because they take it for granted that they don't need too. Also you have to look up the manufactures code to determine the date that the tire was manufactured which not many people take the time to do. JMO
Discussion Starter #19
just to close the loop on this thread..
I found the dealership that serviced the bike over the 10k, there were 5 records
2009 - Sale
2009 - Stage I at Sale - 5mi
2011 - Oil, Bars, Cables - 4000mi
2012 - Oil, Service - 5300mi
2013 - Front tire, Paint fix - 6400mi
Then sold to the owner who I bought it from.. Who said he didn't ride it or like the style. (Was a metrix guy) Kept it until listed for sale in 11/2015.
Generally the story checks out.
I bought it, Thursday
2009 - Sale
Well, there you go.... Congrats, and enjoy. :grin:
1 - 20 of 23 Posts
