1 - 2 of 2 Posts
Anyone have any tips on reinstalling the head unit and getting the weather seal in properly?
Thanks in advance<
Gary
Its Not Fun However
Here is what I did when I replaced my inner. Clean the old glue off the gasket seal and the radio and then clean with rubbing alcohol. Reseal the Gasket seal on the radio using Permatex RTV Silicone Adhesive Sealant. (Get the Corners!) Let set over night. Use a coat of dish soap on the rim of the inner where the radio is at and some on the gasket itself. Not Much. Insert the radio at a slight angle, top first and let the bottom slide in. The corners are a bitch as they are tight. I slid mine in farther than its suppose to go to make sure the gasket seal was still on the radio correctly and Then slide back to bolt it in. Again it wasn't easy but this worked. You'll have some suds around the radio the first time you wash it too. Good Luck!
1 - 2 of 2 Posts
