My OEM radio while riding just goes from being on FM to AUX for no apparent reason. I have had the fairing of and all of the connections are tight there were no lose or frayed wires. When I ran the Diagnostic the code came back; Dia B2008 FC1 Short to GND PN 23-22 (GY-GN). Has anybody this trouble with their OEM radio or where I can find out what the Diagnostic code means. Any help would be appreciated.
Most people just get rid of them for aftermarket units which ill be doing soon too. The stock HK head units arent the best.
Hand controls?
Have you checked the hand controls to make sure theres nothing loose or something shorting out a connection.
In my old motorcycle I had a problem with the ignition switch, it turned out to be a teeny, tiny spiderweb in the contacts.
Good luck!
HSP
Try googling Harmon Kardon radio diagnostics pdf. You will find the instructions for doing a diagnostic on your radio.
