21 - 25 of 25 Posts
Can always add a cheap harbor freight solar panel and battery. Then have option for a fan and led lights or charge anything.
Nice little camper trailer but I can't see where you pitched the roof for water run off or do you just plan on cranking the front a little high or low to put the trailer out of level so the water runs off?
Discussion Starter · #25 ·
The roof is flat. I'll try to keep it level when I'm using it, but when it's parked it will lean towards the front with nothing under the landing gear. It will only have 1-seam in the roof and it will be covered with commercial grade Blueskin that is UV stable. No water is coming in that sucker
21 - 25 of 25 Posts
