Does anyone know if the Ohlins shocks setup for a 2010 Ultra classic, will fit on a 2012 Road Glide CVO?
The measurements are 12 3/4 to 13 9/64 stroke of 3 1/32
They will fit, and if it's for the same person, the set up should be close. Only thing I'm not 100% on is the height....... may be 1" off, hopefully someone who knows that will chime in.
The guy I am getting them from got them from Motorcycle Metal, and he weighs the same as I.
Email Howard at motorcycle metal - he'll be able to tell you.
they will fit , they have a 77mm stroke so you will set your sag at 1" , they have an adjustable eye in the bottom , set at the lowest setting they are 12 3/4" so with a 1" sag you would sit at 11 3/4" at that setting
