I have a 2009 SERG. My light bulb in the oil pressure gauge is not working and my dealer has to order one. Part # 67454-04. Does anybody know where I can get one or is it a Harley only bulb? It is red tinted. Thanks!!!
The stock bulb is a 194. Or you can put in a 168 - same base but brighter. The best option is going LED. LED will be much brighter and has a lot less current draw and less heat. Just make sure it has the 194/168 base configuration.
I had a light go out on mine too. As someone mentioned they are 194 bulbs but in order to keep it the same color there's a rubber sleeve over it. I looked high and low for the sleeves separately but couldn't find any. I wound up buying the bulb from the dealer
Just order that color in an led from superbright, I used the single light led in blue for my 4 small gauges
