my 2009 Road Glide runs well but the oil pressure guage reads around 34 at normal operation speed but close to zero at idle. I have been riding Harley forever but never had an oil pressure guage before and near-zero pressure sounds scary.
Welcome to the tank. Typical example of what happens when a gague is added.
What you are experiencing is normal, typical pressure at hot idle is about 3-5
now all you have to do is add a oil temp gauge, that'll really have you worrying. Put temp gauge beside the oil pressure guage, that way you are not ping ponging between the two.
When i did my cam swap this winter i installed Axtell's oil bypass kit granted it was only 70 this afternoon but running at 2500 rpm in 6th oil pressure was 34 at idle it was 6,before the kit it was 28 at 2500 in 6th and 2 to 3 at hot idle.the kit retails for $80.00 and is easy to install.
