I am wondering what everyone's pressure is when their bike is hot. Mine at idle seems really low about 5 psi. Is this normal and something I should worry about. Oil level is fine too.
Perfectly normal, if your idle is set below 1000rpm you may even get a flickering oil light once in awhile. As long as it runs up in the 30+ range at highway speeds you're fine.
The Softails and Dynas have alot fewer oil pressure complaints, because they don't have a guage................
My oil pressure runs about 15 at hot idle. 34 at speed. I had a new oil pump put in when I did the cams. :D
