1 - 10 of 10 Posts
DS I wish I had some knowledge/experience fiberglassing. GL brotha.
Line the inside with duct tape to close off the gap, then glass in the areas on the outside, remove your "straps" then glass in those areas, grind it down and keep glassing/filling till its smooth on the outside.
Remove the duct tape on the inside, grind then laydown a layer of glass an inch or so wider than what the gap was.
I've repaired lots of semi truck hoods that way
1 - 10 of 10 Posts
