How did you end up mounting it insde the tour-pak ? I would'nt like it just flopping around in there....
Tour pack setup I changed the quick disconnect for water tight and hook it to the battery with a fuse for the mounting location my cable reach to the pouch so can secure charging devices and when not used cover on for safety. Ran the cable along the other disconnect for easy tour pack removal.
Sent from Motorcycle.com App
I'm just leaving it lay loose in the tour pack. I had a amp in the tour pack prior, just came thru the bottom.
