1 - 4 of 4 Posts
Anyone know what the P&A Ignition fuse is for in the fuse box of a 2012 RGU?
The fuse sc:confused:ematic states max. 2A fuse but mine has a 15A in there. That's how I picked it up from the dealer.
I'm assuming that P&A probably means "parts & accessory". Size of the fuse will depend on what you're hooking to the P&A connection. Maybe someone was gonna hook up heated gear????
There are actually 2 separate P&A fuses. One is rated for 15Amps and the other for 2 Amps. The 15amp is powered on the Accy. and Ignition side while the 2 Amp is powered only on the Ignition side.
Maybe these pics will help.
Thanks Triplej for taking the time to snap the photos. This helps explain everything.:D
1 - 4 of 4 Posts
