1 - 3 of 3 Posts
Can I drive more then one set of speakers with a 300X2? I've read that you can wire the speakers in series/parallel and you maintain the ohms? But has anyone out there pushed the Rockford amp and had success? Thanks!
It can be done, I had two sets of 4ohm speakers wired to mine when I had it. (4ohms parallel = 2ohms) Just make sure you match the impedance, if not remember the speakers having a higher impedance than the amp won't hurt you, lower and you're asking for problems.
Sent from my SPH-L710
Im running two sets of Polk Audio dxi 650s off of one PBR 300x2. Just wire them in parallel and you are good to go like dbell stated.
1 - 3 of 3 Posts
