1 - 16 of 16 Posts
Hey all! Put on a few goodies namely the V&H Pro Pipe Chrome and a PCV. All those running 2 into 1 without a cam or other engine Mod's besides a SE breather kit or heavy breather ect, what maps you using? I just started playing with the thing and noticed a significant diff but getting some popping on decel. Not a lot of 2 into 1 choices...
not sure what i am running i got mine from fuel moto jamie came highly recommended he said it was just a plug in play i will have to change it when i put cams in but thats a different time i got alittle popping but not a lot and i am running the klock werks 2:1 and screamin eagles deal
I can't tell you exactly what map, but I'm running Fuel Moto 2 into 1 with a Jackpot slip-on and SE A/C. I had the same problem. Jamie at Fuel Moto had me email the map they supplied, and he sent back 2 more to try. The second all but eliminated the popping, and the bike ran great. If you bought from them I'm sure they won't hesitate to help you out...those guys are great to deal with. Since then I've added an Autotune and they've not hesitated to spend whatever time necessary to educate me on the capabilities.
I had a map pre-installed from FuelMoto, but still had some decel pop. Jamie told me to add 15 to the 0 Throttle position, all the way to 4000 rpm. It did away with the pop and runs great. The original map he gave me was for some other pipe, as they did not have one set up for the RUSH pipe I am using.
I put the V&H Pro Pipe and a RSD a/c on a few weeks ago and I'm still running the stock map. My tuner said to run a few tanks of gas through her to let the O2 sensors adjust and if I was getting any sluggishness or decel pop after that we could look into options.
That was a few weeks ago and she's running great. Noticeable improvement in performance, less heat and no decel pop at all. I'll probably get a dyno at some point, but not a necessity.
You might try it...
Thanks guy's for the feedback! I'm pissed now that my laptop has windows 7 and I can't get the program to work with it!!:mad:
Keep tryin'...PC software is running fine on mine with Windows 7. Maybe Dynojet can help with it?
With Dynojet help I was finally able to down load the application. Hodgeaaco they told me to add 20 but bcuz of the crazy weather, haven't been able to test it yet....
I have Windows 7 and had no problem downloading my map from Fuel Moto.
I have a Rinehart 2 into 1 and Ness AC.
I ran the Ness AC and a different map from Fuel moto as well.
I believe it was the Cooling Map for Street Glide.
Let me know if you need it, i can send it to you.
Man I really appreciate that! Anything is worth a try!!
Discussion Starter #14
Just emailed you the maps.
You will want to use the map labled SG2into1.
I just realized i dont have the software on my new computer, so hopefully it will still work. Otherwise i am in the same boat and may need help installing the software.
Thanks bro, I really appreciate it!! loaded it up gonna ride it 2morrow if the weather holds up!
decel pop
is decel pop bad for the engine or performance? I kind of like it. my bike runs great. SE stage 1 tuner. 2-1 boss fat cat. just turned 4500 miles. tuner installed new at dealership.
1 - 16 of 16 Posts
