Hey all, hoping someone out there may have a PCV map that they can share that will work with my new set up.
I inherited the PCV from a friend, and therefore can not get a map from Fuel Moto (I even tried to purchase a map from them, but all they would do was sell me an AutoTune which I don't want or need)
I had a canned tune on my last set up and it worked really well, so I'm hoping someone here may be able to share a map with me if they have one that's close to my bikes set up??
I have a 2012 RGU with a SE air cleaner, SE255 cams, the exhaust is V&H Power Dual head pipe hooked up to V&H 4" Twin Slash pipes
Any help from a fellow member would be greatly appreciated!!
Go to dyno jets website, tons of maps there.
Thanks, but I went there and they have NOTHING that matches, they don't even have tunes for 2-1-2 head pipes? Weird since all stock head pipes are now that configuration?
Also, any maps that use SE255 cams are for 2008/2009 bikes. Most frustrating!!
Try powercommander.com found a close map for mine.
See above ^^
I've been to the site and nothing there for my set-up.
Thanks, appreciated
Call the tech number on the power commander website. They will point you to the nearest map available for your setup on their site. A better suggestion IMO would be to get your bike dynoed.
Call the tech number on the power commander website. They will point you to the nearest map available on their site. A better suggestion IMO would be to get your bike dynoed.
Thanks for the info 09SN, unfortunately dynoing is out of the question, we only have one competent dyno mechanic within 500 miles of here and his prices are outrageous!!
I will try and call DynoJet and see what they say? I'm sure that Fuel Moto has exactly what I'm looking for, but they're not giving it up!
No problem. I have a setup very similar to yours, except I have Rineharts instead of V&H mufflers. I also have a stage 4 kit on mine. I had mine dynoed. I called power commander and they were helpful, but didn't have any maps for the stage 4.
