1 - 4 of 4 Posts
i just installed a aquatic av radio on my 2008 road glide radio works fine but now my brake lights and turn signals don't work??could i have blown a fuse? it is plug and play made for harley :
Yes check the fuse. If the turn signals and brake lights worked before you did the work and they don't work now then you should go over your work and check everything you can, just installing the head unit should not affect the lights.
i have led lights on the front only could going from the stock radio to the new one be messing with the front lights or the hand controls
i checked my work can't see anything unpluged
1 - 4 of 4 Posts
