I see alot of people are using the Polk Audio DB521 speakers as rear speakers. Has anyone used them as replacements for the front speakers?
I am changing my head unit out to the AquaticAV AQ-MP-5UBT-H unit. it supports 2 or 4 ohm speakers. jumping back and forth between 2 ohm and 4 ohm speakers and also from the Polk Audio DB521 to Hawgwired or Hogtunes. Price for the Polk is GREAT at the moment. The DB are selling for 65$ currently.
thoughts or advise ?
If you're gonna open the fairing to replace the radio then I'd suggest bumping up to 6.5" speakers in the fairing. You can pick up a set of Hawgwired adapters for about $40 online. I have polk db651 in the fairing and db691 in the saddlebag lids with an aftermarket radio and amp. I have no complaints. Plus you'll have more options for a quality speaker if you go 6.5. Just my opinion
Ginee13: have a pair of polk mm651 that were in my glide for a month running off the head unit.i will trade them for a Ben Franklin if you are interested?
Sorry Dozer I Picked up a pair on Amazon for 60 earlier today.
rlaf75
Did you need to make a jumper to connect your speakers. It seems that the speakers thick spade is the positive and that the thick spade on the Harley is the negative. Is this correct ??
rlaf75
I don't honestly remember. The back of the new speaker should be marked as to which is POS and NEG. I don't remember which wire in the bikes harness is which. In most cases the negative wire should have a black tracer. Grab a testlight and see which on has power
