1 - 11 of 11 Posts
I'm putting Gooden time bushings right now.
Discussion Starter · #4 ·
Thanks for the responses but no one has answered my questions. Are the 2015s the same as previous years?
Pardon my ignorance, I'm about to do a swap on my 15 RG...KST 14" outlaws. I have the bars and am itching to put them on. My question is what is all this talk about poly bushings? Should I order some replacement bushings prior to doing the install? I'm still confused on how the key lock assembly comes off etc. So tired of researching this...
bushing
I just removed the trim around the lock and slid the trim off the speedo housing assembly lifted right over the ignition. the switch trim has a single pin toward the tank on bottom and two tabs that slides under in front
Thanks for that info. The bar install that everyone references is for the 13 and under.
One more question..I keep hearing about pins that have to be removed. Is this the case? I can't picture what they are talking about.
1 - 11 of 11 Posts
