1 - 4 of 4 Posts
thinking of having my rear turn signal bar on my 15 R G powder coated my question the coater says I have to remove the wires because of the heat, any body done this how hard is it
thanks
thanks
Look at active threads. There is already a thread going on that will answer your questions.
It's not that hard. It's been a while since I did mine, but basically you remove the bulb, pop out the element the bulb sits in and pull the wires thru. The wires will unplug under the fender.
thanks got some parts at the coater now these will be next.
1 - 4 of 4 Posts
