1 - 20 of 20 Posts
Received my Power Vision from Fuel Moto and I installed it and flashed the ECM with the supplied MAP from Fuel Moto. Super easy took less than 10 minutes ( once I released that I had the engine kill switch on off and it could not read the ECM :)
Overall the bike runs much better than before, smoother, and feels like it pulls stronger during cruise to full throttle roll on. I rode it hard for about 150 miles with a lot of WOT and accel runs so the initial milage was down to about 39 mpg. And I really like not having the PC V on there any more as a piggy back and that Im now using the O2 sensors again.
My question is will the Power Vision always store the original ECM Calibration (MAP) that it kept when it married itself to the bike? Or do I have to save it into another file so that I dont loose it when loading new MAPs. The uinstructions say it automatically saves the original MAP when it marries to the bike , but it also will save the current MAP every time it loads a new MAP.
I want to be sure that I have the stock ECM calibration in case I need to go back to stock for any Dealer issues in the future.
Thanks inadvance for the help.
Dito
I did the same thing you did with the install. I saved the stock tune in my computer and it is saved in the Power Vision. I have the same results and have used a tank of gas on a known rout, fuel mileage is the same or not much diff. I do not have to down shift out of sixth like I use to and less shifting in the twisty turnies in the mountains. Runs alot cooler too. this 103 runs like a 103 now.
11 Road glide Ultra, SE air, Cycle Shack slip ons. love it!
Did you use a Fuel
Moto MAP or one from Dynojet
Ill try to answer if Im reading your question right. Your original map, is now saved onto your PV. You can at anytime load it up to your ECM if you need to go back. Your stock map is no longer in your ECM, only the map your currently running. Your ECM only has 1 map in it at all times,. your PV on the other hand can save up to 6 if memory serves. I have 3 saved in mine including the stock map. Its also a good idea to hook your PV up to your computer and save the maps as a backup just incase. Ive even read where some guys make a 3rd copy on a zip file.
Thanks Chainsaw.
Ill save it to my PC as well.
Bought this package on 09/13 (see below). Very easy install. I cannot believe the difference in my stock 2009 FLTR. Wish I had done some meaningful pretesting so I had something to compare before and after. Can tell you this: On a downhill run from Mt. Bachelor to Bend on my stock bike, 100 MPH and she was all in. After the Fuel Moto install on a flat run from Redmond to Bend, I backed off at 110 MPH. Also the best stock fuel mileage I ever got was 47 MPG on a solo Bend to Reno Street Vibrations trip in 2010. Wednesday I made the same run with a passenger and baggage for 2 at: 72MPH, 2800 RPM, 6th gear and averaged 51MPG on each of 4 fuel stops. At 2800 RPM I'm still in the 14.6 AFR range but the bike seems to be running cooler. Shoulda done some pretest to prove/disprove this. I did change to Mobil 1 Syn just before the trip and was able to buy non-ethanol fuel while in Oregon. Also the Jackpot 3.5" Dyno tuned mufflers are extremely pleasant on a long run. There's just gotta be some reason Fuel Moto made the mufflers side specific and added extra baffling to the Left side. I believe their claim they are 'Dino tuned'. There is one thing I wouldn't do again on this install. I removed my fuel tank to run the PV wire concealed. The wire has no end covers so to protect them when I remove the PV, I cover both ends with electrical tape then tie wrap the overlap to keep the tape on. Kinda a pain when U want to play with the PV. Do need to contact Jamie to see if a new cable is available.
Oh and another thing. I had a fault code show up during the maiden run. #B1123. Had to take it to WildHorse Harley on the Saturday before my trip to Street Vibrations. I left the PV on my handlebars and plugged in. I wanted the Dealer to see exactly what I had done to the OE ECM. I really thought they would claim I had caused the fault. In fact the service order read: "Dyna Tech Power Commander installed prior to problems - Coincidence"? No problem with my flash of the ECM or the PV install. They did replace the Brake/Turn Signal Module which corrected the fault code. It does seem that running the bike with the PV on causes some fault codes but none that require action.
Well that's it! Unscientific and undocumented. But I would say this is the best $$$ I have spent on this bike. And I'm gonna be preaching the benefits to anyone who will listen. I do believe that the Fuel Moto total package is required to reap my benefits
2009 FLTR Road Glide. Total stock - and gonna keep it that way!
OOPS!!!! After 15K miles I couldn't stand it any longer. Installed Fuel Moto's 09 Touring Package, ie; JP Tuned Muffs, SE Air, PV Tuner......
If you travel, I'd recommend saving the stock map and the one you're using on a thumb drive so you can carry it with you. Never know what you might have to do on the road.
what is the map number Jamie had loaded for you ? I have mine installed but milage no where what your getting
Tune from Fuel Moto:0809-96-JPSlipons-205.pvt Possible the Jackpot Slipon's are responsible for the wonderful mileage or maybe I'm running too lean? Who knows.
Discussion Starter #11 (Edited)
The number wont help since Fuel Moto MAPS are not listed on their web site, they are made availabe to their customers free for life. You need to e mail Jamie and have him or Keith e mail it to you. They are not public info like the MAPS on the Dyno jet site.
Im averageing 40 mpg and I ride it hard all the time a lot of WOT starts etc.
Its another one of the reasons to buy from them, double thje warranty and lifetime tech support
Did 275 mile easy ride yesterday with some new riders so we were just cruising and I got 46 mpg for the day :) bike ran great.
With the mods you have, I'd be very happy with those numbers. What slip-on pipes are you running? Also, TOTAL newbie question, but with the PV do you have to leave the touch screen unit attached all the time (like on the handlebars), or do you just plug-n-flash, remove, then leave the screen in a drawer at home? Sorry for the ignorance! :confused:
With the mods you have, I'd be very happy with those numbers. What slip-on pipes are you running. Also, TOTAL newbie question, but with the PV do you have to leave the touch screen unit attached all the time (like on the handlebars), or do you just plug-n-flash, remove, then leave the screen in a drawer at home? Sorry for the ignorance! :confused:
Suggestion: If you haven't done any mods, I suggest you contact Jamie at Feel Moto. He is offering dyno-tuned, side specific mufflers that are excellent in value, sound and quality. For less than $1000 he has a package: Mufflers, SE AC, PV and a tune designed specifically for your bike.
you can get a mount and leave it mounted and select the gauges that you want to display, or you can flash your bike, unplug it, and leave it in a drawer at home.
Thanks for the info. No, I haven't done any performance mods yet. I'm waiting for my 1K service...and extra cash! I'm definitely considering fuel moto or drago's based on what I've read on this forum. I want to go with black exhaust so it kinda sucks that u have to buy new black heat shields w/ the FM headers. Still for the money, service, and performance looks like u can't go wrong with either company.
Thanks. That's what I figured but wanted to make sure. I already have my GPS mounted (on Iron Aces mount) and wouldn't want a PV mounted full time either! Also it sounds like with the PV you retain an open loop system w/ the O2 sensors, and it records the stock MAP, which I like. Thanks for the info and sorry to OP for jackin the thread a bit!
Discussion Starter #19 (Edited)
No you dont have to leave the PV mounted on the bike, I just plug it in and flash the ECM and remove it. It only stays on the bike if you want to use it to monitor or gather data for self tune
I highly recommend calling Jamie at Fuel Moto for more info . I have had the SERT, Fuel pak, PCV and now the Power Vision on my Harleys and Im most happy with the Power Vision for ease of use, performance, ability to monitor and check and clear codes, and that it still uses the O2 sensors for closed loop tuning.
Im using the V & H Power Duals with the V & H 4" Black Out Rounds with Quiet Baffels for exhaust. if I had it to do over i would probably go with either the Fuel Moto 2-1-2 ceramic header or Fulsack X Pipe and American Custom Black Heat Shields or possible even aAmerican Custom Stock catless headpipe and either Black Rineharts, Black American Custom Bombers or if they were available my first choice would be Fuel Moto Jackpots in black but they did not have them before. The reason i would not do the V & H Power Dual again is clearance, it scrapes before the floorboards and my stock pipe did not .,
Xaran, that's some good advice, thanks man! That's why I love this forum! I just got my RGU and haven't done any performance mods....yet. I will definitely do a Stage 1 upgrade, and lord knows it doesn't come cheap. What I don't want to do is what I've done on other bikes; jump in too quick and buy shit you eventually end up replacing. I already have enough crap in my garage. I'm still torn on black or chrome. My only concern w/ going blacked-out is having the shade of black of the heat shields matching the same shade of black on the slip-ons. I'm really liking the FM 2-1-2 ceramic headers, but damn, gotta spend extra coin for a black heat shield!
Anyway, thanks for the info on the PV. Regardless of the exhaust I go with, I'm pretty sure I'll go w/ that tuner. And before I end up spending any $$ on exhaust I'm also going to contact FuelMoto or Drago's. Thanks again for the sound advice...
Mike
1 - 20 of 20 Posts
