1 - 20 of 29 Posts
Bought the mount and visor from Fuelmoto to mount my Powervision to the handlebars. Works pretty good...pics below
Looks good.....
Just keep it out of the rain . They can stand a little wet but they will not stand up to it long. Ask me how I know.
Looks good I mount mine right in the center.
Looks good. You'll like having the PV mounted when you ride. I mainly use mine to monitor engine temp, as I also have Ward's cooling fans.
I mounted mine with Velcro.
Mine is just ran under the edge of the tank by the fuel line. I can pull my cable off quick and easy. You can't see it though.
How did you guys run your cables?
High recommend pulling the tank and running the cable through the cable tray on top of the frame backbone. Running under the tank can cause issues caused by electrical interference from the ignition system. It may not do it today, but as the heat slowly degrades the insulation on the cable(a problem all in itself) you will eventually see problems.
Discussion Starter #14
I have had a few issues with mine and that could be the problem. I need to run it the right way. Thanks for the advice...:D
I ran my cable this way also. Very easy to do and everything works just fine.
I mounted mine with the iron aces mount. Still tough to see in the day time. I also ran my cables under the tank. I put the auto tuner in the space by the battery where the ABS would go, (I don't have ABS).
Don't know how you have your gauges set up, but I have better visibility in the sun if I set them to the night time screen (black background with white numbers). Not a total fix but it helped me.
Under tank I was able to carefully fish it through without remove tank
remover front and rear bolts propped it up a bit
Thx moco, I'll try it
1 - 20 of 29 Posts
