1 - 20 of 33 Posts
Just noticed a clicking noise as I was backing the bike up in the garage while not running today. Started it up and put in first gear to pull it forward and shut engine off. Backed up again and clicking noise remained. The clicking speeds up the faster you back up. My guess is tensioners? Called and made an appt for them to check it out under warranty at the dealer. Any thoughts on what it may be?
Your moving the bike without it running so it can't be the chain tensioner because the chain isn't moving without the motor running. You will sometimes get a clicking or squeaking noise from the drive belt when backing up. The belt tries to shift to the inside of the sprocket and causes the noise. It will not make the noise when you push it forward because the belt centers itself again
Gonna take it for a spin for a whiskey run and see if it continues...
Mine squeaks pretty good when i back it up. Makes a little more than a squeak sometimes.
Sounds like something other than the final belt to me.
Seriously though... Have you tried putting it on a jack and moving the rear tire? Are your brake pads still good?
Soumds to me like your belt is too tight.
Sent from my SPH-L710 using Tapatalk
Put it in gear and pull in the clutch and do the same, backing up and pushing forward. Does it do it when you do this? If not, you have something going on in neutral with the transmission or possibly the bearing are gone on the final drive shaft or the bearing race could have walked. Maybe something as simple as the nut has backed off on the transmission belt pulley. Next step is pulling the primary cover and inspect with the back wheel off the ground and rotate the wheel to hear it better. Next is pulling the compensator sprocket and clutch basket to get to the inner primary and remove to get to the belt sprocket.
Edit: Before you pull all this, lift the back wheel off the ground and rotate the rear tire with the bike in neutral of course. Still make the sound? If it does proceed with above steps.
Of course if the bike is in warranty, let Harley worry about it.
Wow that's loud. Sounds like somethings hitting, but could be a belt thats way too tight. Either way, I'd get it up in the air & see if it does it, & see if you can pinpoint it from there. But. .....like Smarty said, if its under warranty let the dealership handle it.
Lil Chief
Do you still have the baseball card in the spokes? >:)
LOL that's what I thought of too! Haven't put it on the jack to check it no. I'll try that today.
Reactions: RGKen
Discussion Starter #14
Lil Chief
Great info, thanks! As I stated before, I have already called and made an appointment first thing tomorrow at the dealer. He assured that it would be covered under warranty. He also said they have all the parts in stock to repair what it may need. Hopefully they can get it fixed tomorrow without an over night stay. Gonna have them trouble shoot the ticking during cold start ups too if it stays overnight.
Bummer Man
Good Luck & I Hope They Can Fix It Fast For You.
I know you take care of your bike and hopefully it's something simple.
Swomack
Discussion Starter #16
Bummer Man
Swomack
Thanks brother, I'm looking at it as an opportunity to get new parts, and maybe some new upgraded parts, out of pocket of course. Thinking HD clutch spring in prep for cams, and possible lifters if they look at the cold start ticking. Maybe even rockouts if they agree to do the labor under warranty. >:)
Cams, Lifters & Heavy Duty Clutch sure sounds good. When time is right I will be doing those upgrades as well. Once again good luck brother. let us know the final outcome.
Swomack
Discussion Starter #18
Will do. Just put it on the jack and spun rear wheel. Still clicking
Wheel bearings or rear pulley bearing are usually the culprit. But that is a unusual sound so it could be a clutch hub bearing or a inner primary bearing or a tranny bearing too.
1 - 20 of 33 Posts
