1 - 13 of 13 Posts
Does anybody have a good way of priming the oil system after an oil change? Whenever I do it I have to do a start/kill start/kill until i think the oil pressure is back up and where it should be. I thought about taking the plug wires off and just turning the engine over. Any tips?
Priming is not necessary. Just start the engine and let it idle, the oil pressure will go back to normal in just a few seconds. Its no different than changing the oil in a car engine and starting it afterwards. You would be surprised at how long an engine can run at idle with no oil pressue and not sustain any damage.
+1, don't need to prime it!!!:D
The method I use is to add oil to the new filter before installing it. This method is not in my HD manual but it is in my Buell Cyclone manual. I know the engines are quite different but the idea should apply to both... when the oil pump starts to pressurize the system the filter will already have a supply of oil to send out into the engine passages. I also use this method when changing oil in my cars.
Just spin on the filter and fill engine with oil and start the engine, beer is optional but recommended. Putting oil in the filter can result in a oily mess. Also you should wash the oil off the front motor mount the oil has a tendency to ruin the rubber on the mount resulting in motor mount failure.
You don't need to put a whole lot of oil in the filter... my Buell Cyclone manual states: add 4.0 oz of oil to filter and screw filter onto filter housing.
As far as making an oily mess on the front motor mount, read HD_SHOCK's write up in this area under: "No mess oil filter change." I use this method almost to a "t", and it has worked for me... never had to wipe up any oil yet!​
We always add oil to the filter before re-installing, always. It is easy to do and doesn't really take more time to do with the guns we have....
I think everyone has their own way of doing things. None are neccessarily wrong. I say... no rules! Do what it takes... and ride!
Put me in the "add oil to the filter" camp. I have been doing it since working on my '72 Galaxie 500. The filter element soaks up the oil you put in there so it doesn't leak out.
Does it make a difference? Probably not, but it doesn't hurt.
1 - 13 of 13 Posts
