1 - 12 of 12 Posts
These have less than 1000 miles on them. Bought them for my 2012 Ultra Classic and ended up trading it in a couple weeks later.
They are set up for us with the 140 lb springs as we ride 2 up 70% of the time. I'm 200 lbs & my wife is 130 lbs.
Asking $750
I’m interested, if they can work for my weight 240 riding solo most times
I would think so with the adjustment they have but don’t know for sure. I would suggest a quick call to George or DJ at Pro Action and they could confirm yes or no.
I see you're in Canada so I have to ask. Is that CDN or USD? :ROFLMAO:
Dan good deal right here.
How easy are these to adjust to a 200lb rider that is 99% of the time solo?
I should jump on these
As mentioned above...I can't say for sure so don't take my word on it. I would recommend a quick call to George or DJ at Pro Action at 724-846-9055. They could confirm yes or no.
Yep, Saw that...I asked Train as he is very familiar with them......I have been going back and forth on if I want to add shocks or not - I am not 100% dissatisfied with the stockers and told myself I would keep an eye out for a deal
Should be pretty easy. The threads on the preload adjusters are coarse rather than fine (like Ohlins uses), so there's much less turning required to adjust for a passenger.
With that said, 140# springs might be a bit heavy for you if you're solo most of the time. I go about 210, and believe I have 120# springs.
Looking at the pics, if the OP has the preload set to solo, you'll be okay....You may just get a smoother ride with a lighter spring.
1 - 12 of 12 Posts
