1 - 17 of 17 Posts
Just installed Custom Dynamics Pro beam Front/Rear LED's on my 2018 Road glide special.
The good...
Signals/brake lights are VERY bright. To the point you would have to have your eyes shut not to see them. :grin::grin:
The bad...
One of the rear lights had a ground wire that was not connected so my left rear running /turn/brake light did not come on. :surprise: NOT impressed for a $110.00 set of rear lights. So quick action with a tiny bit of electric solder and the light works fine. No problem, it works and I will toss it up to a fluke.
Test it in the shop and the probeams come on and blink at a normal rate of speed. However even though the lights themselves are blinking at a normal rate of speed, the green turn signal indicators on my dash are blinking at 3 times the normal rate.
Any ideas? I was under the impression that you didn't need to run turn signal load equalizers with the 2018 bikes.:serious::serious::serious::serious:
I would give custom dynamics a call, their stuff is usually plug and play. I have used their products on many bikes with zero issues.
It's got to be something simple, maybe a defective part?
Keep us posted!
I'm running the old school Custom Dynamics front and rear on my 17, took them out of my 09 before I traded it in. Working great so far. One of our other RGS riders had the new PB, no issues so far, but, then again he's a bit of a slow poke so I really don't see the back of his bike that often! I agree, you should contact CD, they have a decent customer service department.
installed same set on my '18 FLTRX and no problems.
did you clean out the dielectric grease as per instructions?
did you run flashers for a few minutes?
i've heard their customer service is very responsive so should be able to cure with a phone call. let us know how it works out.
I just put the same pro beams on my '15 FLTRXS and I have no issues. They are incredibly bright!
This seems to fix most. My 15 RGS it didn't fix it. Even after 5 min. But it doesn't bother me because the actual turn signal is fine to cars.
The good...
The bad...
You don't need a load equalizer, just turn on the hazards for 3 to 5 minutes and let the computer sync them. Had to do this on my 16 as well. I should have read the whole thread first before chiming in. Doing this synced mine perfectly, if not CD has great customer service give them a call.
Ok, so to be fair to the company I will say this. The lights are very bright, look great, and are IMO well worth the money. It would have been nice if I didn't have to have to solder on a brand new light but, as I stated above I will toss that up to a fluke. They seem to be a stand up company from what everyone says.
I will contact them just so that they are aware of the problem I had, maybe they will do a little better quality control . I see no need to send it back as it is working fine now.
Anyways, here are some pics and I'm very happy with the end results.
CD has excellent customer service. I had a 3 year old light go out and had a new one 48 hours later. They even stood behind another manufacturers product when I couldn't get them to respond just because I purchased it from them.
I'm blind! Maybe a warning :) They look great
Reactions: BigBlockBobby
1 - 17 of 17 Posts
