1 - 4 of 4 Posts
Installing my 250 watt J&M amp . I noticed on the back, there is a small button that has an in and out position. It has RCA written above it, and I cant recall what is below it?
Does anyone know what that button is for and if it should be in or out? I would like to get the fairing put back on tonight, rather than waiting till I can call J&M tomorrow
JMJOHN
Baldwookie ,,,
that is the high level-low level (rca) input switch ,,,,,,,
on the older 250w ROKKER amps, you want to use whichever position on that switch works (literally) ,,,,,,,
on the later model units, that switch has no purpose as they are all RCA input (only) ,,,,,,,
how does it sound now that you have the system ROKKIN ? ,,,,,,,
John,
Your right- it either works or it doesnt! Got it all hooked up and tried and HOLY COW what a difference!!! And I havent even put the fairing back on yet.
I will have a 1200 mile ride to Shark week and I will be jammin the entire way thanks to your stuff!!
Cant thank you enough!
Mark
1 - 4 of 4 Posts
