Hi, anybody happen to know what the tps/map/rpm range is adjusted under the "tweaks" when you select Low or mid or high? Even knowing what input it references would help?
Looking to lean out the cruise range a touch ( 50-60MAP, 2,900-3,000rpm ) when on long slab ride and temps on the cool side to boost fuel economy. Do not want to adjust tune permanently.
If anybody knows of a better/easier way please let me know.
As an aside, can not get it to display VE or afr within the gauge options. I can select it, just get's no signal?
