1 - 3 of 3 Posts
when ordering the MOCO factory packs , (2014 ' Candy Orange ) if I'm not mistaken , you get a pint of each ,(the base coat AND the Candy coat ) correct ??? also the big question , does the base or the candy coats require activator mixed with them ??? When using HOK candys I have always had to use activator with the candy … if so please advise on what part number activator I would ask for at my PPG supplier …. I assume the reducer will be the PPG std , temp range spec reducer ? thanks in advance
1 - 3 of 3 Posts
