1 - 14 of 14 Posts
I've got a new 10in windvest in the mail and was wondering do I have to use the rubber windshield trim with it? I just removed a 8 in Klock werks and it was installed without the trim.
windvest
FYI, I'm running a 14" windvest. I didn't use the trim with mine.
However I have 2 large black faucet washers at each fastner between the windshield and fairing. This will let some air through which reduces the negative pressure on the back side of the windshield. Reduces the buffeting.
I've not seen that before but makes sense. Can you dimension these large faucet washers for me, diameter and thickness? How much gap have you created? Is the windshield firm or have a lot of flex?
I have a 10 inch on my 2015 withe factory screws and washers. At this point all is good. 10000 miles. The shield itself works well for rider and passenger, after trying 4 other ones. The dark smoke looks good on the black bike.
Like to hear and see more about this. Im in to try it.
The faucet washers are probably 1/2" to 5/8" in outside diameter, and 1/8" to 3/16" max thickness . I'm guessing at this point.
I believe that the larger outside diameter will give your shield better support.
I used the OEM hardware ( screws and wellnuts) with no problem. If the center hole of the washer is small just drill it out.
As you know faucet washers are typically a black hard rubber type material. They blend right in with the bike and windshield.
No issues whatsoever with stability. Probably have 40k miles on my bike with this set up.
This set up slightly simulates the madstadt? Windshield but looks better in my opinion.
Thanks for the reply. Bike has some parts at the powder coater now, perfect time to pick some up and try.
I'm for giving this a try, but one last question. I have a bunch of faucet washers but they all are flat on one side and convex on the other, are yours shaped similar? I'm thinkin' flat on both sides would be better.
You can buy the rubber W/S seal at the dealer. It has some adhesive for the W/S to stay in place. Apx $20. I'd suggest you replace all the hardware with new. Do a search & you'll find some helpful info on replacing your W/S & hardware.
You are absolutely correct, you definitely want the ones that are flat on both sides. I have been very happy with this simple
Modification and truly enjoy the ride.
I am definitely going to put my shield on this way when I put things back together. At least to try it out. Thanks for the idea Tim
If you go to the faucet repair section at Lowe's or Home Depot they have the rubber washers in different sizes and flat on each side. Also in the screw isle, they have the metal draws with specialty items and have some rubber washers too.
1 - 14 of 14 Posts
