I honestly don't remember, it's been awhile, give Frank a call.
What kind of problem are you having?
How do you verify that a map is loaded into the ECM via the TMax program?
Connect your computer to the bike. Turn on the power and run switch and hit "Link". It should show you which map is loaded. If you have a different map on the ECM than the one loaded in the software, you will get a warning that the maps do not match. Or you can go to Map Editing, then READ Module Map and Settings. You will have the ECM map for sure at that point.
I have had TMax since 2003. I'll be happy to help you in any way. I live in Cumming. PM me for my cell number if you have questions. Always happy to help out a shark owner!
