2021 Ducati Multistrada V4S
I am helping a friend disassemble a lot of parts on his RG for powder coating. He wants to remove the top three crank case bolts (just below the jugs behind the shift linkage) to PC them. My question is will it mess up anything just to remove the bolts to PC them and then re-install? Thanks in advance!
I wouldn't do it it is the 3 main crankcase bolts holding the top of the crankcase together. Buy new bolts and powder coat them then change 1 at a time.
Most in likely nothing would happen because the cylinders are torqued down but you could risk having a oil leak.
