1 - 3 of 3 Posts
I installed a Dynojet Quick Shift unit. All I can say is what took me so long? It's a whole new experience now. Highly recommend if you like rapid up-shifting.
So what is it that this doo-jabber does?
It allows me to up-shift without using the clutch lever. What you see in the picture is a pressure sensitive switch that signals a control module which then cuts power to the fuel injectors to momentarily unload the drive line.
Can you shift without using the clutch without this unit? (yes) But this makes it fool proof!
1 - 3 of 3 Posts
