1 - 4 of 4 Posts
I installed the Sony DSX-MS60 with biketronics module for handlebar controls. Everything works fine....until I put in gear and ride. Once on the road, the radio just starts cycling thru different features (lows, high, mids, balance, fade, etc....) I cant use the controls. Occasionally it will stop long enough for me to turn up/down volume, but then goes right back to cycling through features.
Has anyone had this problem???
Yes I had the same problem. I went through two biketronics modules and got tired if it and swapped it out for a hawg wired module and now it works flawless.
From what I have read on the net it's a common problem with the biketronics unit.
Are you sure the radio is not in a "Demo" mode? Check the main menu in the radio and see if there is a "Demo" that can be turned on and off.
Pull apart all the connectors in the system and then secure them back together. It sounds like one of the connections is breaking contact at every bump
1 - 4 of 4 Posts
