1 - 4 of 4 Posts
I was out rideing when my radio display diappeared , but the i-pod kept playing . An hour and a half later it came back on but the clock was off by the same time the display was gone.The i-pod played the whole time. Anyone else seen this problem?
The HK radios have been unexpectedly crapping out since they were introduced in 2006. Unfortunately, the dealer mantra "they all do that" applies here. They should make "install new radio" part of the regular maintenance schedule.
Really?!
warranty is 12mo 12k mi - even with ESP
dealer has swapped many out - :: rant ::
could be moisture in face or vibrations
hope you find it, usually everything will come back and be fine
try air drying real good that area, park in the hot sun
So the two year warranty doesn't cover the HK radio?!?!
If you cntinue to experience this problem and you're still in your 2 year factory warranty period, take it back to your friendly, neighborhood Harley dealer and see what they say.
If they don't provide satisfaction, try Iron Cross Audio.
They'll straighten it out for you.
Good luck!
HSP
1 - 4 of 4 Posts
