1 - 3 of 3 Posts
So I installed a set of RF T165's in the inner fairing of my 09 glide. I ended up taking the inner fairing off and using a hole saw to drill it out. When I took apart all the wiring harnesses I labeled everything. Now that I have put the fairing back on and connected all the wires, the harmon radio will not power on. I checked the fuse but it was ok. Any ideas?
Check all the wires. I had some warranty work done on mine and they ended up having to cut some zip ties. After that my left speaker didn't work. Once I finally had time to troubleshoot, found that they accidentally cut the speaker wires.
1 - 3 of 3 Posts
